メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
No output audio on MBP Retina, only startup chime
My MBP Retina 13" 2014 A1502 has no audio output device. Only on startup do I get the start up chime, then I have no output from loudspeakers as well as from the headphones jack.
What I've tried so far:
  • Reset NVRAM, SMC reset
  • Format and Reinstall of OS X El Capitan 10.11
  • Create new admin user
  • Startup from Safe mode
  • Apple diagnostics show no error
When sending audio via bluetooth to a wireless speaker works fine, so I think the soundboard is OK. Also the systems loudspeakers seems to be OK, as I can hear the startup chime.
Any idea?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
If there is no red light inside your headphone jack, I would check System Preferences / Sounds / Output to make sure Internal Speakers are selected.
If there is a red light inside your headphone jack, it means your Mac thinks an audio plug is inserted.
I've read of people wiggling a headphone plug or a toothpick inside to reset the internal switch.
If the switch itself is damaged, the audio port integrated into the main logic board; and the whole board would need to be replaced. It's an expensive repair. MacBook Pro 13" Retina Display Mid 2014の基板の交換
Good luck.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I have no Output Device to choose on that list. What red light do you mean?
さんによる
he is talking about a red light from inside your headphone jack
さんによる
Yes, sorry I wasn't more specific. If you look into the port you usually plug-in headphones or speakers, there is a red LED that will light up if the hardware thinks a plug is inserted.
さんによる
コメントを追加
回答を追加する
Santiago さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 13
今までの合計 309
