メインコンテンツにスキップ
1.86GHzもしくは2.13GHzプロセッサ、フラッシュストーレッジは128GB もしくは256GB
147回答 すべてを表示
Why is Wi-Fi hardware not recognized?
Hey there!
A friend gave me an old Macbook Air with networking problems, with the question if I could fix it for her. The problem is: the laptop cannot connect to Wi-Fi. The Wi-Fi icon does not show up in the top bar. When I go to 'System Preferences' then to 'Network', and click the '+' icon, 'Wi-Fi' does not show up as an option under 'Interface'. The only options there are 'Bluetooth PAN', 'Bluetooth DUN', 'VPN', 'PPPoE' and '6 to 4'.
Even when I go to 'About this mac' , then to 'System report' and then to 'Wi-Fi' under the 'Network' tab, I only see some software specifications. It seems no Wi-Fi hardware is recognized.
As far as I know, the original owner already reinstalled Max OSX. I have also tried to reset NVRAM and the SMC, but this had no effect.
Is there anything I can do to fix this issue? Is the next step forward to replace the networking card? Or are there more steps I should take to make sure whether that is the problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
最も参考になった回答
I have had about six machines in with Wi-Fi problems in the last couple of months. I fixed them all by running Symantec Endpoint Protection and getting rid of their viruses. On a couple with extension infections, I also had to reinstall a system after cleaning them.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
Most likely the Airport card is bad. Follow this IFIXIT guide: MacBook Air 13インチ Late 2010 AirPort/Bluetooth カードの交換 and here's the needed part: MacBook Air (Late 2010-Mid 2012) AirPort/Bluetooth Board
MacBook Air (Late 2010-Mid 2012) AirPort/Bluetooth Boardの画像
製品
$29.99
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Fabian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 7
今までの合計 65
