メインコンテンツにスキップ
touch not working after battery replacement
Hi,
I have a iPad model A1395 with defect battery. So i replaced with new battery and tried to charge it and it works fine. But then i want to test the touch before i mount the screen back with adhesive... now touch not working and only home-button is working.
Shouldn't the screen work while it's open like iPhone screens when its not completely closed?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
4件の回答
Hello Ibrahim Ibo, If you opened the iPad there are ribbon cables to make the touch sensitivity work i recommend that you reseat the cables inside the iPad then try again if this doesn't work clean the connection then try again.
Hope this helps
-Activoid
Update - the cable should look a little like this
このアンサーは役に立ちましたか?
スコア 0
14 件のコメント:
can you please show me picture of this cable?
さんによる
tried to disconnect the cable at both ends, still no responsive :(
さんによる
have you tried cleaning the gold connections on both ends such as the Logic board connections and the ribbon cable connections
さんによる
what can i clean with? 100% alcohol?
さんによる
I wouldn't pour it directly onto the board but put just a tad bit on a cotton ball and just dab it onto it that should work just fine then let it dry for around 15-30 minutes don't wipe it because then you can risk damaging the connections
さんによる
9件以上のコメントを表示
コメントを追加
When opening the iPad did you accidentally tear the flex cable for touch glass? Inspect carefully.
If all looks good. Try slowly bending the touch glass around while touching and see if you get a response at a certain bend.
Next make sure the touch flex is properly seated in its connector on the logic board and that no pins were bent
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
There you go, i taked two pictures. One of the Home button component, and one of the 2-pin over the charger-component
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Make sure the cables are not torn or ripped, they can rip pretty easily. If they are damaged purchase a new screen, they're relatively cheep. If they're not damage take the cables out and put them back in again. There is a white line on the cables
make sure the white line is parallel to the plastic screen connector. Also make sure the latch on the screen connector is closed.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ibrahim Ibo さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 10
今までの合計 210
