Using Suction Cup to remove screen with a screen protector
Can you still use the suction cup to lift up the screen if you have a glass screen protector (ZAGG) installed on the screen or will it lift off the protector?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You can use suction cups no problem but on cracked screens the glass tends to separate from the palstic frame if it is an after market screen.
I always use razor blade on sides of screen to lift it up after taking out the two pentalobe screws.
このアンサーは役に立ちましたか?
Brian, you can use a suction cup to remove the screen. The screen protector won't come off
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 4
過去 30 日: 15
今までの合計 2,375
1件のコメント
Thanks for the answer. Worked like a charm. Battery replaced in about 20 minutes
Brian Thompson さんによる
