Pull the engine to replace a timing belt on a 1991 Camry?
Do I have to go as far as removing the motor to replace a timing belt on a 1991 Camry? Anyone know of a good website I can download a repair manual for my car, for free?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Does not read like you have to remove the engine, but definitely the engine mount on the right. Not a fun job but doable...besides the advise that ABCellars gave you here is another website that has some info
このアンサーは役に立ちましたか?
No, you don't have to remove engine. It's sufficient to hold engine with jack and block of wood underneath oil pan. Shouldn't be too much of a hassle...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 2,064
