メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
293回答 すべてを表示
Any potentail for upgrading GPU cooling?
How is the cooling configured inside the 2017 27" iMac?
Is there a heat-sink on the GPU?
Is there space to attach one if there is not?
Are there any potential options to improve the cooling for any of the core components (i.e; replace thermal compounds with higher performing ones, attach heat-dissipation to GPU/CPU that currently lack any)?
Thanks!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Lets try this, Install this app: TG Pro it will allow you to see the internal thermal sensors and whats happening with the fan. Once you have it running take a snapshot of the main window when its at a point you are getting concerned of the running temp and paste it here for us to see iFixitでの質問に画像を追加する方法.
As far as your direct question your system has two heat sinks one for the CPU and a second of the GPU. Both feed the heat to a fin system for the fan to extract the heat and push it out through the back of the system. I would leave the cooling system alone as it as its quite good, unless you have something show up under TG Pro. Then we can see what actions would be needed then.
The simple steps is to make sure the vents along the bottom and back are not blocked so the system can breathe. Also make sure you've not over taxed the system running processes which are over stressing it.
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I will give that a shot and share what I find as soon as I have some results.
However, my question is less aimed at fixing an existing problem as it is in preventing a problem. I use my iMac a great deal for Photoshop/Lightroom and the like; but, I also boot into Windows fairly often to play games.
The impetus for my question is in trying to improve duration for peak performance by reducing thermal throttling (if it ever occurs).
さんによる
コメントを追加
I think 'thermal throttling' occures when the GPU reaches 80°C resulting in lower fps (i did quite some testing now). I would like to improve the cooling capabilities as well and thought of this: The foot/stance of the imac is an external heat sink of some kind. The exhaust is venting the hot air directly onto it. Maybe one could add a fin/heat dissipation thingy with thermal glue to it. Right above the hole for the power cable. Then use a quiet fan.
Not sure hot to measure the success though. I guess a GPU temperature of 77° C with 300 less RPM on the main fan would be an improvement. It'd go from "noisy as !&&*" to "I can live with it".
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
How about running TG Pro so we have something to work with. The link is in my original answer.
さんによる
コメントを追加
回答を追加する
Soli Ramsdell さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 9
今までの合計 1,702
