Why does the turntable not rotate?
Unable to open case because screws are hex with a pin in the center that keeps a tors bit from unscrewing the screw. I would like to replace the motor for the turntable.
この質問は役に立ちましたか?
Here is a [リンクされた製品が存在しない、もしくは無効: IF145-044-1] that will help you crack the case on that sucker. Once inside, most microwave turntable motors are fairly simple to remove. I've heard that people go around scrounging them out of the trash because they're slow RPM motors that take 120v. Perfect for your disco ball or other slow rotating needs.
コメント:
+ good answer. Disco Ball? ;-)
oldturkey03 さんによる
Every home should have one ;-)
pollytintop さんによる
I have a lava lamp, does that count? ;-)
oldturkey03 さんによる
dunno...do you dance round it?
pollytintop さんによる
only after listening to ABBA and to much Alvin Stardust ;-)
oldturkey03 さんによる
評価: 1
There are some security screws that protect the microwave from opening by everyone. The screwdrivers that open this class of screws are sold on any tool store like harborfreight.com or Enco. They are not difficult to find, but cannot be find everywhere as other screwdrivers can be found.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 4,511
What is the brand and model number of your microwave please?
ABCellars さんによる
