メインコンテンツにスキップ
The 2016 version of the Samsung Galaxy A3 budget smartphone (model number: A310F).
59回答 すべてを表示
What can I do to fix a pink/purple screen with a white vertical line?
About a month ago, I dropped my phone killed my screen and I had it fixed.
Last night while I was charging my phone, it fell!
When I picked it up the first thing I noticed is that it had a vertical white line that ran from top to bottom and the area where the line was located could no longer work.
Then I noticed some pink/purplish lines running in all directions on the screen!
Now the whole screen is a pinkish purplish colour and the part of the screen where the white line was originally located has started to turn black, it is slowly progressing and I am guessing that by the end of the day my screen will be completely black.
Also, my screen isn't broken!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Only solution is to replace the screen again.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
  • sounds like you were playing a video.if you switch tabs during a tab many times it will come.remember,it might be 4 times
  • it could be screen problem
  • joining a meeting+playing a video ,it will come like that
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
you`r screen will also off,please off it and on it again
さんによる
コメントを追加
回答を追加する
thea sku さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 26
今までの合計 9,630
