メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号はNV370です。高さは27インチで、Sharkの「吸引力が持たない(never loses suction)」技術と回転ステアリングを搭載しています。
Power Brush won't rotate
First time using the Power Brush on my new Shark Navigator, 5 stairs into it, sounded like it picked up something and the brush quit rotating. I immediately stopped, removed the tool and tried to find what was stuck. I see nothing stuck. I can't even rotate the brush by hand, if attached the belt just slips, with the wheel removed that holds the belt, I still can't get the brush to rotate by hand. I can move it maybe 1/2 inch but that's it. It's locked. The cover will only lift to about 1 o'clock if that makes sense, then it stops. The instruction book looks like it is removable and I might be able to remove it by prying it off the "pegs" on the end, but don't want to break it. Any suggestions?
I was able to get it off the pegs to remove it. I can force turn it a little more, but it still does not turn when the vacuum is on. I tried both settings just to be sure I wasn't using the wrong one. Neither makes the wheel turn.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
If your Shark Navigator Lift-Away Pro vacuum’s floor roller no longer spins, see the Shark Navigator Lift-Away Pro Floor Roller is Not Spinning problem page for possible causes and solutions.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
What if non of those work then what
さんによる
コメントを追加
回答を追加する
J John さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 6
過去 30 日: 27
今までの合計 3,466
