iPhone 7 stuck in boot loop after screen replacement
I have an IPhone 7 stuck in boot loop after screen replacement.
I already tried to restore, didn't work.
Tested battery and the screen on a different phone and it works fine.
The only way I am able to boot up the by disconnecting the screen assembly completely and iTunes will recognize the phone and it seem to work fine.
How would you fix this issue?
この質問は役に立ちましたか?
No, I will update the thread if I do
oliverkoppel さんによる
Please do. I am having the same problem with 2 7's
cd70451 さんによる
I had the same issue with a 7...I was replacing the factory Apple screen with an aftermarket...started boot looping upon installing new screen...disconnected the screen and restored entering DFU mode...thought I fixed it...nope. Connected the screen (aftermarket) back and it started boot looping again. So frustrating.
musick.jesse さんによる
I have a iPhone 7 with a broken home button, apart from that it was working fine, it is stuck in a boot loop due to the home button. Is there any home fixes for this? Even just a way to get it to turn on?
Dylan McLaughlin さんによる
