メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Repair guides and support for your LG TV.
Fuzzy bottom half of screen
I have an LG 55UF6450-UA. The bottom half of the screen appears fuzzy but when viewed closely, I notice that every other scan line seems to be grayed out. The top hallf of the screen is ok. Also, sometimes the bottom half of the screen will flicker. I tested this with the menu screen displayed and no external input connected. I was wondering if this might be the t-con board?
This shows the dual scan lines with some grayed out. Notice the top half of the screen is ok.
This shows a closer look...
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
7 件のコメント
See posted images...
さんによる
I have the same exact problem with a LeEco L434VCNN.
Any update on this issue?
さんによる
I have the same problem LG 42LM620T. Please let us know if it worked or not..
さんによる
My LG just started the same exact thing today, in time for COVID-19 and no school, etc. Any solutions?
さんによる
Need schematic for LG 55UF5460
さんによる
2件以上のコメントを表示
コメントを追加
2件の回答
ベストアンサー
@tilson looks like it could be a bad panel. You can of course try a new main board first, but horizontal lines etc. are usually caused by failed Gate Drivers on your panel. Take a look at the side of the panel and see if there is a circuit board that has small ribbon cables going into the inside of the panel. Check on that circuit board and try to exert some pressure on those ribbon cables. See if that changes anything. Again , a picture is worth a thousand words ;-)
このアンサーは役に立ちましたか?
スコア 3
8 件のコメント:
I tried a new t-com board but got the same results. I am considering a new main board because the bottom portion of the screen seems to flicker back and forth between normal and lines with a ghost image and it seems to me this might point to the main board. I did try pressing on the ribbon cable at the places where it entered the panel but there was change. If I can get a main board, I'll let you know what happens. Thanks
さんによる
@tilson that sounds like a plan. Let us know how it works out.
さんによる
hi did you solve it? I have an LG TV with the same issue
さんによる
The T-com board didn't work. I'm still waiting on a main board to try that. (They're hard to find.) If anyone knows where I can get one (that can be returned if it doesn't work) at a reasonable price, please post the info here. I need a EBT64048903.
さんによる
Check the power supply while your waiting. The power supply was my problem with the lines on the screen.
さんによる
3件以上のコメントを表示
コメントを追加
I have this problem. Not sure what to do
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Tilson さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 11
過去 30 日: 73
今までの合計 25,118
