magsafe charger is overheating and sometimes laptop does not charge.
The charging symbol sometimes has a white background with the electricity signal but it often does not charge the macbook.
At this point you're going to need to pop the logic board out and do a detailed inspection on both sides. Follow this IFIXIT guide: MacBook Pro 13" Retina Display Mid 2014の基板の交換. I'm suspecting you have some corrosion or a failing chip on the logic board.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 513
Did you have a liquid spill or sit the system down on a wet surface at some point?
Dan さんによる
