メインコンテンツにスキップ
2014年10月22日発売。このモデルより、指紋認証「Touch ID」が搭載されています。
61回答 すべてを表示
Has anyone had a problem with the Digitizer Adhearing?
I’m having a problem with the replacement digitizer adhearing along the home button side. (bottom) The digitizer cable seems to be pushing up on the digitizer causing the adhesive not to fully cure to the housing. Any suggestions? I’ve tried reheating and letting something sit on it overnight to hope that it sticks. It’s almost as if it needs thicker adhesive. Any recommendations at this point would be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
thanks! i’m going to pick one of those up and finish the silly thing up.
さんによる
コメントを追加
1 件の回答
ベストアンサー
There's not a lot of adhesive on the bottom side of the digitizer and a lot of stuff underneath it. You have to make sure the flexes are properly sitting within the device as even the tiniest amount of pressure will eventually cause the adhesive to let go of the digitizer.
The actual adhesive matters also. Was the adhesive initialled or did you apply some yourself? I find that the pre-installed adhesive is generally low quality and doesn't stick as well as a high quality adhesive, such as the Tesa tape you can find here on iFixit or pre-cut 3M tape from Bowler-Tech, which is what I use ( I remove the pre-installed tape first).
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Eric White さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 3
今までの合計 53
