Where I can get this charging port
Now my phone is dead for a whole month because of a small piece
i am looking for that piece because it is damage can you tell me where i can buy it or what is its the correct name for it?
My guess is it would be the charging port daughter board.
https://www.eddogo.com/for-one-plus-onep...
Is it the charging port assembly or the connector on the logic board broken?
If it's the connector on the logic board broken you will need to take it to someone that does micro-soldering to replace the part, they most likely will have to order a replacement FPC connector for that too.
このアンサーは役に立ちましたか?
it is the connector on the logic board
do you know where i can order the replacement FPC connector??
過去 24時間: 1
過去 7 日: 2
過去 30 日: 6
今までの合計 409
