メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
Home Button Part Working after Screen Replacement
Hey All!
I hope someone can help me. I've been fixing iphones for years with no real issues for friends and family that is until now!
Ive just replaced an Iphone 7 LCD for the 1st time and I was incredibly careful transferring everything to the new display.
All looks great but the Home Button is behaving very oddly! There is no error so the phone is accepting it but for some reason it will only do half of what it should.
It won't wake the phone but it will accept a finger unlock if you switch the device on with the power button.
It won't return to home screen with a single press but it does accept double Taps to lower the screen down.
Its kind of like its not understanding the haptic feedback correctly even though it does appear to part function and the phone is accepting it.
Has anyone else faced this issue and does anyone know of a solutions. The replacement screen was one purchased by my friend from Ebay. (Its not OEM but appears to be very good quality.
Thanks in Advance
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
Only thing I can think of is the screen being defective, the home button extension cable is part of the screen assembly.
If the home button looks undamaged, that's probably the case then.
If you want you can try restoring the phone, make sure to backup the phone via iTunes before doing so as it will wipe all data on the phone.
このアンサーは役に立ちましたか?
スコア 2
6 件のコメント:
Heya I officially feel like a fool! It turns out (As my friend took it to a shop) that I had accidentally mixed up 2 screws from the home button. The guy switched the 2 screws and full functionality is restored.
Thanks for responding I had thought much the same as you but on this occasion it was me.
Good warning for future amateur fixers apparently the order of screws makes a big difference... strange thing is I'm so careful i don't know how i would have switched them...
さんによる
Yeah it is strange, glad it was a simple fix.
I'll note this down for when someone else has the same issue.
My guess is that the screw used for the home button is designed to be non conductive.
さんによる
So bit strange. The phone came back appearing to be a ok then went mental after an hour. Same issue its like the home button sensor can't work out how much pressure there is on it.
My friend took it back to the shop who then claimed he needed an Official Apple Screen for £90 which seemed reasonable fitted and makes sense over some cheaper clone option.
Screen fitted and it worked great... for an hour... now were back to square one. The home button acts however it pleases and it is very very frustrating. If anyone has any advise at all it would be highly appreciated.
Kind Regards,
Brad
さんによる
I have the same problem but changing screws doesnèt seem to fit it.What screws were changed
さんによる
Wil be the four screws that hold the home button in place, the one in the back of the homebutton is slightly shorter.
さんによる
1以上のコメントを表示
コメントを追加
Don't Apple replace the Homebutton and screen as a whole unit?
I'd take it back to them and claim it was working fine before. May get a replacement phone free of charge!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, apple replaces screen and home button as a whole unit which would eliminate this issue ultimately.
さんによる
コメントを追加
回答を追加する
Bradley Sparkes さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 8
今までの合計 854
