メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
半田付けは、2枚の金属の間にフィラーとなる別の金属を溶かして接続する方法です。 はんだ付けには多くの種類がありますが、この記事では電気を使った半田付けの基本について扱っています。
How to desolder charging and micro usb port?
Hi,
first of all, I tried to replace 2 charging port for laptop motherboard and one micro usb port for a tablet and I destroyed all the boards.
I'm feeling like I don't have the right tools.
Basically, I never tried to solder anything, because I just can't desolder those ports. I don't have flux. I'm wondering if without flux I should be able to desolder?
It takes like 1 hour to remove all the tin then there still have some tin everywhere that I can't remove with my desoldering brain and the port is still stuck there. Finally, the board just burn.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
Is there a guide to desoldering a mini USB port that is built into a flex ribbon cable? I would rather replace the entire ribbon but it’s no longer for sale anywhere, so my only option is to desolder the damaged port and solder a new one to the flex ribbon cable. Any suggestions would be appreciated.
さんによる
@F P Old post I know but!, Always a but. If a component is soldered to a flex ribbon you can hold the iron horizontally and hold the ribbon with the component on the iron shaft near the tip on the flat bit. If you use flux it will soften the solder in no time and the part can be removed to be used again. (May need 3 hands or a friend to help)
さんによる
コメントを追加
2件の回答
ベストアンサー
@geekinside you will need flux and desoldering braid. Check this video as well as this guide はんだ付けとはんだ除去の作業ガイド.
このアンサーは役に立ちましたか?
スコア 3
6 件のコメント:
Hi oldturkey,
I saw alot of guides and I thought I was ready.
I have the desoldering braid, but I am not sure if the desoldering process should be easy without the flux?
I mean, every guide and video I see, the desoldering process seems simple and easy. However, when I try it takes me 1 hour to remove the half of the solder.
さんによる
No it is not. you will need flux for the desoldering. Most likely your solder does not even get hot enough and thus will not come off. Tin your soldering tip use flux and the braid and it will remove the solder. You do need both, flux and the wick/braid. It is actually not a terrible complicated job with the right tools. Practise on an old board and you'll be surprised how quickly it will work.
さんによる
Thanks alot my friend.
I'll buy some flux and I wish you a wonderful day.
さんによる
I recently attempting desoldering for the first time on a USB B port on an audio interface. Even with normal (the one that came with the iFixit soldering workstation) desoldering braid I couldn't get the solder off. I purchased some new desoldering braid with flux in it, is that definitely going to work now? I was researching around during this, and found some people using a thing called a desoldering pump. Is that something that works good and would be worth investing in?
さんによる
@ezra all you need is a good braid and plenty of flux as well as the right heat. a lot of practice will help as well. Try it first on a board that you do not need. You will need to learn when it is to hot and destroy your solder pads or when it is to cold and you will pull the solder pads of with the component. Desoldering pumps are cumbersome and will not work as easy as youtube videos make it look.
さんによる
1以上のコメントを表示
コメントを追加
It is hard to desolder with soldering iron. You can only desolder using heat gun facing on top of the component with tweezer holding the component to remove.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
alex さん、ありがとうございました!
統計データ:
過去 24時間: 7
過去 7 日: 19
過去 30 日: 82
今までの合計 22,133
