メインコンテンツにスキップ
1998年に発売された任天堂ゲームボーイのカラー版です。このデバイスの修理は難しくありません。
74回答 すべてを表示
I have a problem with my gbc screen cnat really explain it
so I had i problem with my select button at the start
I tried using the eraser to clean out the select/start part on the mainboard
after I re-assembled it and turned it on, the screen wasn't working properly
it does turn on, but the starting logo (gameboy logo) show only the outline
and ofter that nothing will show on
I tried turning the contrast screw but nothing seems to help with the problem
nedd help! thank you
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
My best guess would be that you shorted something out with static electricity while handling the board. If that is the case there is no easy fix if any depending on which part got damaged. But of course that all depends on your environment. Do you have carpet on the floor? Do you like to wear woolly shirts?
If so you probably should discharge yourself by touching something grounded like a metal sink before working on hardware.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Have you tried giving the screen ribbon cable and wipe, you might also want to try cleaning the ribbon connector on the mainboard. Use a Q-tip in rubbing alcohol to clean up the ribbon and connector, ensure you let it dry out and then test the results.
Hope this helps.
Kieran
ZedLabz
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
임희상 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 3
過去 30 日: 4
今までの合計 343
