メインコンテンツにスキップ
2015年9月25日に発売。モデルA1687/A1634。このデバイスの修理は前モデルと似ています。スクリュードライバーとこじ開けるツールが必要です。GSM もしくは CDMA。容量は16、64か128 GB。カラーはシルバー、ゴールド、スペースグレイ、ローズゴールド。
1041回答 すべてを表示
Front camera quality turned bad after Glass + LCD Replacement
So I recently repaired my iPhone 6s+ after the screen cracked. I ordered the glass + LCD replacement kit from repair parts plus and everything was great. I transferred over all the small parts from the old screen (including the front camera) to this new LCD. After checking the front camera, however, I see that the quality is not as good as it was before. It's useable, but looks like an Android quality front camera; can't capture details. The quality gets worse with front flash. I've opened up the phone again and made sure everything was how it was supposed to be, and even gently cleaned the camera once again. There are no scratches on the camera, it looks brand new. Id really like to fix this issue and get the good quality back on the front camera. The only explanation I can think of is that maybe this new replacement glass isn't perfectly clear or maybe the diameter of the transparent circle over the front camera is a millimeter too small. Please let me know your thoughts!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
6件の回答
Is this a preassembled screen with front camera already installed?
If yes, you may need to transfer the front camera from the old screen into the new one.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I transferred the old parts, including the front camera, to the new screen. I forgot to include this detail in my post, thank you.
さんによる
コメントを追加
Try removing the plastic cup for the front camera, it's not needed, if this doesn't help then try the camera hanging off the screen, if it's still bad then order a new front camera.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have the same issue. We’re you able to fix it? If yes, how?
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I also have the same problem with Samsung A10 though it started immediately after i replaced the screen which had cracked badly off but at that time my front camera was working just fine.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Did you manage to fix this? Got mine replaced today and the front camera is horrible..
さんによる
コメントを追加
Android is not a camera but software
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Cheap quality aftermarket parts are your culprit. That's why you should always get it repaired directly from manufacturer
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Read the room, J U; you realize this entire site is all about NOT having to send your devices to the manufacturer for repair, don't you?
And I completely disagree with your implication that all aftermarket parts are cheap quality. Yes, there are a significant number of them that are, but there are also many examples of high quality parts that are as good as or indistinguishable from the original manufacturer's parts. I've replaced more iPhone screens than I can count and encountering a defective aftermarket screen has been a rare exception rather than the rule for me.
さんによる
コメントを追加
回答を追加する
Mohammed Hossain さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 11
過去 30 日: 55
今までの合計 11,068
