メインコンテンツにスキップ
The Xbox One Wireless Controller model 1697 was released in 2015 and replaced the model 1537 controller and fixed some of the problems found on Model 1537 controllers. The Model 1697 controller includes an integrated 3.5mm headset jack, which allows compatibility with most 3rd party headsets without the need of an adapter. This controller has been discontinued and replaced by the Model 1708 controller.
75回答 すべてを表示
How to remove the trigger pins holding the bracket?
Hi, first time posting.
My Xbox one trigger has broken. I've found the root cause of my problem. The Trigger bracket (not the piece you unscrew), has snapped on one side. I need to remove the metal pin/rod that holds it and the spring in place.
However, I don't know how this pin is in place or how to pull it out. There's literally nothing on the internet about these pieces.
Help is appreciated
Regards
Jonathan
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
4件の回答
ベストアンサー
I was just looking for this answer because my bumper broke and i had to order a new one and was cheaper to get an entire shell and all parts, i ended up having to snap one of the brackets because the pin is shaped like a gear and they must heat it then put it together so it makes a tight as seal, what you want to do is from the inside push that pin back out, you will need something with a fine point like a sowing needle, Just make sure you don't put the needle through your finger, or squeeze the pin between a pair of pliers and that inside bracket, Then when the thicker end of the pin is sticking out grab it with your pliers and pull it out, That should fix your pin problem mate, Hope this helps you some.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
So long ago. But cheers for the reply. I might pull it back apart and have another crack at it.
さんによる
コメントを追加
https://www.youtube.com/watch?v=NZp8Rcik...
This video helped me figure it out.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Grab the tapered end and the broken bit and squeeze the pliers, this will push the pin out on the opposite end. DO NOT push from the non rounded end because that side has a slightly bigger end that will not go through
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
This was extremely helpful. Just takes a lil time and a steady hand to complete it. Thank you managed to fix mine
さんによる
コメントを追加
Whatdya mean push the pin out from the inside? Is this different from pushing from either side? I’m hoping I can just buy new ones, as to not damage the cover plate.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Use pliers to push the tapered end through by grabbing the tapered end on one side and the broken braket piece on the other side of the pliers
さんによる
コメントを追加
回答を追加する
Jonathan Saunders さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 14
過去 30 日: 43
今までの合計 3,349
