Cannot remove the screw inside magnetic cover
I've tried to unscrew it for literally 5 minutes.
I'm sure it's loosened but it doesn't lift.
It's just stuck in the cover.
it has no hard drive in it, give it a smack. alternatively, do the other screws and it should still come right off as the screws are not anchored.
このアンサーは役に立ちましたか?
i've tried to smack it but feared that the hinge will be broken.
And what do you mean the second option? just pry it anyway since the middle one isn't anchored? It does feel stiff when i try to pry the edges.
Oops! I forgot to check if we have a guide, just follow this guide. Dell XPS 13 底面カバーの交換
このアンサーは役に立ちましたか?
this doesn't mention the middle screw...
i'm confused right now whether or not i should force it...
Hmmm... whats your model?
its xps13 - 9350
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 351
