メインコンテンツにスキップ
2017年9月に発売されました。モデル番号はA1863、A1905。GSM もしくはCDMA/容量は64か256GB/ゴールド、シルバーとスペースグレイ
873回答 すべてを表示
Replace watertight seal after screen replacement?
Is it possible to retain water resistance on iPhone 8 after opening it up to replace cracked screen? Is the adhesive replaceable?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
最も参考になった回答
You can replace the seal, clear off the old adhesive with solvent and bamboo toothpick, then align and apply new one. Use firm pressure to make sure they stick well.
However you cannot make sure it will be watertight because you replaced the screen, an external part. Apple don’t sell these assemblies as official repair kits, how are you going to make sure that your new screen is properly assembled in the first place and is watertight yourself?
So don’t even try unless the screen is original and you are only replacing internal parts like batteries or rear cameras.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
I'm not sure we have a good handle on how Apple is applying the gasketing adhesive to regain the same level of waterproofing.
I would say the act of opening the phone reduces its tightness no matter how you try to reseal it at the end of the repair.
Even Apple does not warranty the waterproofness after you get a phone serviced (read the paperwork you get from a repair).
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Yes the adhesive is easily replaced go have a look around the ifixit shop I think they may have it, if not eBay or if in the States shop jimmy or ipad rehab shop are worth a look.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
anthony_islas98 さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 6
過去 30 日: 15
今までの合計 11,127
