Digitizer and LCD is splitted, is there any way to merge them?
As title says... Is there way to merge LCD and Digitizer on iPhone 6?
Image:
You can buy some thin adhesive strips and cut them accordingly to what you need. They may not be a permanent fix, however it will be your best bet until you can get your screen replaced.
このアンサーは役に立ちましたか?
And I should split them until they are totally splitted? I mean LCD and Digitizer so I could use adhisive
You don't want to purposely separate the two pieces just to add as much adhesive. However do what you can for now. But remember you can always order another screen from iFixit to replace the one you have.
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 29
