"No battery available" after battery replacement
I completed installation and the new battery functioned properly, so I let it drain until dead, recharged to 100% overnight, and today the battery indicator says “No battery available.”
I’ve tried SMC reset and NVRAM reset and the error remains. I also did the hardware test (holding ‘D’ when booting) and it came back clean. It shuts down when I remove the power cable so I can’t drain it, and when I boot up it momentarily shows a 100% charge.
Anyone encounter this and have a fix?
Edit: Here's the coconutBattery screenshot:
Why did you replace the battery in the first place?
Dan さんによる
@danj The original had the "Service Battery" indicator, had over 700 cycles, and its capacity was down to 5000mah
Tyler さんによる
Where did you get the battery?
Dan さんによる
Amazon, sold by Temark
Tyler さんによる
