メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
586回答 すべてを表示
MacBook Pro 15" Early 2011 not powering but charger shows green light
I'm making some upgrades on my laptop so it currently does not have a battery installed inside of it. I am only relying on the AC Adapter as a power source at the moment. With that being said, when I plug the charger in, it lights up green as if there was a full battery inside. When I press the power button, nothing happens. The logic board just sits there. I tried jumping the power pads but that didn't work either (maybe I did it wrong?). Is my logic board dead? I was told that if it were dead the charger wouldn't even be lighting up. What can I do?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
I'm using a 60W charger and in order to use the AC Adapter as the only power source, I need to have an 85W charger. Is this true?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Review this Apple guide: Find the right power adapter and cable for your Mac notebook. Make sure you have the correct charger for your system. Also be careful you get a REAL Apple unit! There are a lot of fakes out there!
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Thanks, Dan! Getting a new charger fixed the issue. My laptop is able to turn on now.
さんによる
コメントを追加
回答を追加する
Cameron Torres さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 268
