メインコンテンツにスキップ
A personal computer that resides in one location with its core components inside a case separate to third-party peripherals required for operation, such as a mouse, keyboard, and monitor.
542回答 すべてを表示
How to Plug in Headphones when the Jack is broken?
So, about a year ago. I broke my headphone jack by accidentally tripping over an earbud cord connected to it, and the port is stuck deep inside.
Now, I have recently gotten a pair of Turtle beach Headphones! But It doesn't seem to work as I can only connect one port inside.
Any suggestions on how to fix and use my headphones?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント
about how much is in there and how deep?
さんによる
Ah! My bad,
my earbud adapter is stuck inside.
Its deep enough where I can't get it out, even with the super glue method.
さんによる
コメントを追加
1 件の回答
ベストアンサー
Hi,
What is the make and model number of your desktop or the make and model number of the motherboard if self built?
Where is the headphone socket? On a panel in the front of the computer case or at the back of the case on the motherboard?
If it is on the front of the case usually the "audio \ USB panel" (example only) is connected by cables to header pins on the motherboard.
The simplest way to resolve the problem, if your setup is like this, is to replace the panel containing the audio socket
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
回答を追加する
WaterWolfGaming さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 1,199
