Mac SE Error 0000000E 000000FF
Sad Mac error code: 0000000E 000000FF
What do I do?
Thanks
From what I could find, It seems to be a bad CMOS battery. I couldn't find much more. Good luck though.
このアンサーは役に立ちましたか?
Few points to add:
Was the logic board recapped and cleaned?
Did you try and change or reseat the memory?
When was the last time the machine worked properly? Last week? Or 10 years ago?
CMOS battery (actually it is called the PRAM battery on these Macs) would not cause much problems on these machines if it goes flat, however it might leak after all that time and destroy the logic board…
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 11
過去 30 日: 23
今までの合計 1,725
