メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
LG Stylo 3 Plusは、2017年にT-Mobileから発売されたAndroidスマートフォンです。5.7インチのHDディスプレイ、32 GBのストレージを搭載し、オペレーションシステムにはAndroid 7を採用しています。
Capture+ won't work anymore
My capture+ won't take a screenshot the screen stays blue and there is a homescreen lock at the bottom of the screen
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Have you found an answer? Mine has always been like yours and I can't find a way to make it work at all
さんによる 共有
コメントを追加
4件の回答
最も参考になった回答
I have the stylo 4 and all of a sudden it wouldn't capture the screen any more. I kept getting a pink screen in the memo format. I had been fooling around and changed something. Just didn't know exactly what. Finally figured it out. At the top right hand corner u can change the paper if you press the 3 dots for more settings. Press paper style. Then choose the one that isn't a blank page. It worked for me, hopefully for you too.
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Yes! Thank you!
さんによる 共有
Thank you so much!!! I had this happen to me too - I was trying to figure out how to write on a picture (to sign a form) and must have changed it not knowing what that was. Then when I tried screen shotting, it wouldn't work anymore! Thanks so much for the tip!
さんによる 共有
コメントを追加
Your need to take a screen shot, either with the capture+ or power button. Aftewards you'll see 3 doors at the top right of your screen. Tap the dots and select paper style. Select the option with the picture, not the blank paper. This will allow you to write on your screen shot.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Android has a built in screen capture capability.
Hold Vol Down + Power at the exact same time and it will take screenshots.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
I can take a screenshot that way but the capture plus feature is supposed to let you take a screenshot and then write on it. I've yet to find a way to do this. My capture plus screen does exactly as described by the person who asked the original question here and always has since I got the phone
さんによる 共有
コメントを追加
Oh I forgot, press the little lock down in the left hand corner so that it looks unlocked. That should unlock it. Good luck.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Debra Murray さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 10
今までの合計 3,829
