メインコンテンツにスキップ
モデル番号A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5もしくは2.8 GHz Core i7プロセッサ
432回答 すべてを表示
Do I need to replace the thermal paste?
I'm opening my iMac to install an SSD. Since i'm opening it already, I thought, what else can get better here ?
So, should I replace the thermal paste/pads ? The CPU is currently at 57ºC, idle, and the fans are running at 1400 RPM (room temperature is about 28ºC) . Of course the back of the iMac is hot, as expected, but the screen is hot too. I don't know if that's expected to happen.
In the case of a replacement, what should I use ? I've heard of K4 and K5. Why those and are they really necessary? Are pads better? What about Arcticlean remover ?
Thank you in advance.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
最も参考になった回答
It is necessary to put any thermal pads back and reapply thermal paste to places where the thermal paste was disturbed. Thermal paste needs a good seal without air bubbles. you also do need to clean off the old thermal paste before reapplying 放熱グリスの塗布方法 first thing said in the guide:
{caution sign} Thermal paste is responsible for conducting heat from the processor to the heat sink. Reassembling a computer without applying thermal paste will cause the processor to overheat, resulting in permanent damage.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Hi Enrique,
Have you replaced the thermal paste? did it help? I have a mid2010 27" that is also hot on the back and on the screen.
I've already opened and cleaned it out but am thinking on getting an SSD and wondering if it's a good idea to replace the thermal paste and whether it would help or not.
Thank you!
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
Actually I decided not to give myself all that trouble.
I haven't replaced it, also haven't measured temperature in a while but its about the same as when I first posted.
Instead of replacing my HDD with an SSD, I bought an ssd adapter for the optical drive (not sure what they really call it). I then removed the Optical Drive and placed the SSD there. This way you have waaaay less things to worry about, and is also a much faster procedure.
On my 2011 iMac, I get SATA II speeds, can't get III via the optical drive sata cable. But it is still so fast I can't notice the difference. My computer feels like a new one (actually even faster than a 2015 dell laptop I've got, with an i5 processor that is 4 years newer).
Not sure if you will get SATA I or II speeds on a 2010 machine tough.
To sumarize, I haven't touched my processor, I don't think this temperature is a problem and it's definitely not affecting speed.
Hope this helped!
さんによる
It surely helped!
I think I'm gonna do the same and stop worrying about the temperature thing. I've been monitoring my machine and it seems to be "normal".
I also have SATA II available and that optical drive adapter seems to be a good ideia. I'll take a look on it.
Thanks again!
さんによる
Yeah, I think that's the best way to go.
Sure, you're welcome!
さんによる
コメントを追加
回答を追加する
Henrique Mazer さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 14
今までの合計 4,373
