メインコンテンツにスキップ
Repair guides and support for the Acer line of netbooks including the Aspire One series.
How to add a SSD without a Hard Drive Input?
Hi, have been trying to install a SSD hard drive into a Acer Es1 111 net book. It currently has only 13gb of space (with only around 1gb left). I opened it up to find that not only was there no hard drive, but there is not even a Sata socket for the hard drive to go into (as there is in the disassembly videos I have watched). There are pins where it is meant to be.
Is it still possible to install a hard drive, or get a wire to connect the SSD to the motherboard?
I will try to link some photos below.
Thanks for your help!
Sasha.
Update (01/20/2018)
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
Plse add your full Model Number ie. Acer Es1 111-xxxx
for better identification of your model
さんによる
コメントを追加
1 件の回答
最も参考になった回答
Hi!
It looks like your netbook does not have the port you need, although the pins for the SATA socket are present (it's the little holes that go from the tip of that printed arrow to the next empty screw(?) hole. It is possible to install a SATA socket in there with a little bit of soldering, tho it could get risky as you may end up damaging other stuff on the board with the soldering iron.
PS: You could get a SATA to USB adapter and use the SSD as external storage. Also look if your laptop has an SD card slot. You could return the SSD and buy a high-capacity SD card instead.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
#just to add.. it may also be possible that the SATA controllers are not embedded (not present) on the boad which even after soldering a SATA socket it will still not work!!!
さんによる
@galmoham Of course, that is another thing to consider.
さんによる
コメントを追加
回答を追加する
Alexander Kolomiytsev さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 688
