Can I upgrade the logic board on my Early 2015 MBP Retina?
My Early 2015 MBP (A1502) which I could only afford the 2.7Ghz/8GB/128GB is getting a bit long in the tooth so to speak. I impulsively ordered a used 3.1Ghz/16GB (820-4924-A) which the listing said is compatible with all A1502 MBPs (Early 2015). I'm confident it should be a one-for-one swap, but aside from the hardware swap, is there anything I need to do software wise? I have strong tech skills when it comes to hardware but am a luddite when it comes to the software side of things. One more thing to note (if relevant), I replaced the stock 128GB SSD with a 512GB oem unit which is working great. Thank you in advance guys, this is such a rad forum and resource!
Update (01/20/2018)
Also, how much of a performance upgrade should I be reasonably expecting?
Update (03/20/2019)
@dark_ritual - It works great! Good luck!
この質問は役に立ちましたか?
8 件のコメント
Your systems specs: MacBook Pro 13" 2.7 GHz i5 (Early 2015)
The logic board you got specs: MacBook Pro 13" 3.1 GHz i7 (Early 2015)
Dan さんによる
I am looking at doing this exact thing. Same MacBook Pro, same specs, same upgrade. And I wanted to get some advice. How did this go? Did it work out? Anything to look out for? I’m looking at embarking on this swap by next week.
Any info would be an awesome help.
Thanks John @scrivs
Alfonso Vega さんによる
Hi! how is it working? did it work with no problems?
I have the same model A1502, Macbook pro retina early 2015, 2.9Ghz, 8Gb Ram and 512GB…. I was planning on upgrade to a new 2018 macbook pro but is really expensive and honestly.. I don’t trust the new keyboard and certainly will miss the ports….
So I know that the only thing I need for now is to upgrade my RAM to 16Gb… and I know that the only option is to change the logic board…
Was it only plug and play? In my case I’ll be using the same original 512Gb SSD…
Thank you!
Alejandro さんによる
I would like also to know if the upgrade works before buying.
thank you!
doublewardrummer さんによる
It works great! It’s really a pretty simple process, no messing with the software, which was my only concern. I’d call it a plug and play evolution. Good luck, post up here if you need any help!
john Scrivener さんによる
3件以上のコメントを表示
