メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Processor overheating after battery and screen replacement.
Hey, today I tried to change my battery of my iPhone 6.
Old battery removal and putting the new one in was quite smooth. To change the battery easier, I removed all four screen cables and also speaker module.
After I put it all back together, noticed that after ~10 sec. after startup, processor gets really hot. I can feel it even from the back of the phone. After I did a little research about the problem, found out that it may be the front camera cable. But the camera and front speaker works well.
Any ideas what can cause this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Same thing happens with me but my phone gets turned off and to start up i have to press of the display connector and then the phone will turn on. Kindly help
さんによる
コメントを追加
2件の回答
最も参考になった回答
It could be your battery too. Batteries that do not discharge properly can cause overheating. I would try to put the old battery in as a test.
このアンサーは役に立ちましたか?
スコア 1
8 件のコメント:
I`ve tried connecting battery from another iPhone 6, nothing changed. :/
さんによる
Ok, try disconnecting your camera cable and booting it up.
さんによる
Does not change anything.
It heats even when the screen is fully disconnected.
さんによる
There must be something else wrong at the board level. My suggestion would be to send it a person or company that does board level repair and diagnostics to see what the issue is.
さんによる
I’m using the phone right now. Noticed that the proximity sensor is not working at all, but the front camera and light sensor both work well. And phone heats just when the screen is in use.
So maybe I just damaged that cable of the screen and now proximity sensor shorts the processor with low current?
さんによる
3件以上のコメントを表示
コメントを追加
Reball cpu
n problem will be solved
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Paulius さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 5
過去 30 日: 17
今までの合計 5,502
