メインコンテンツにスキップ
Appleの2世代目のiPad AirでWi-Fiモデルのみを対象をしています。モデル番号はA1566です。
214回答 すべてを表示
iPad will not activate after reset
I bought a used iPad Air 2 it was restored, removed from an iCloud account - it was in fine condition and had no physical marks.
iOS 11.2.2
Latest iTunes 12.7.58
However, when I try to setup it up. It will not activate - it says that the Apple Activation Server can't be reached I tried everything ifixit.com is probably my last resort. PLEASE HELP
In iTunes it says, and this is the weird thing, (I can't remember exactly how iTunes puts is but it's something like: "The Activation Status of the device cannot be retrieved because there's a SIM-card inside and it's protected by a PIN)
This is a Wi-fi only model, people.
I tried:
1. Activating it through different Wifi networks on both channels and through iPhone tethering
2. Activating it via iTunes on two different Macs running Yosemite and one Windows 10 PC
3. Activating it through Apple Configurator 2
Please help!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
コメントを追加
2件の回答
ベストアンサー
What you bought may not be what you expect...
I am speculating here but you may have an GSM/LTE version of the logic board inside a regular housing. There is a hardware "fix" that allows you to circumvent iCloud locked LTE boards. It allows them to function as a WiFi-only model though.
Where exactly did you get this iPad? Do you have any recourse or ability to find out more about it's history?
このアンサーは役に立ちましたか?
スコア 3
7 件のコメント:
Hi Minho! Thanks for your reply. I bought in on Craig’s List and it was restored when I got it. However, there’s wasn’t an internet connection where we were at the time (we could have used tethering though) during the transaction and everything seemed find and it was in mint condition and no physical marks on it indicating the device had been tampered with. And I saw when the previous owner removed it from iCloud.
Tell me more about the “hardware” fix.
さんによる
http://gsxcloud.com/hardware/icloud-bypa...
I doubt this "fix" works with current versions of iOS. That may be the problem here when you restored it to the latest release, the unlock fix was disabled by Apple.
さんによる
Same problem here, Activation Error occurred after restore.
さんによる
Did you have it fixed?.I have the same issue except the fact that the logic board is for the wifi only iPad Air but the housing is for the cellular version.
さんによる
I have the same issue I tried putting the iPad on DFU mode it still shows the same error message and when connected to iTunes it says disconnect your iPad make sure the sim card is inserted and if you have a sim pin.tap unlock to enter it and then reconnect your iPad
さんによる
2件以上のコメントを表示
コメントを追加
DO you think the activating it using a lightning-ethernet adaptor will work to activate it? The iPad is still able to find wifi-networks.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
i am also get this problem with Alexander, i do many ways to active but failing. i really be hate the ipad no sim, too hard to fix this
さんによる
コメントを追加
回答を追加する
Alexander Pontikis さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 13
過去 30 日: 50
今までの合計 12,297
