メインコンテンツにスキップ
モデル番号A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5もしくは3.5 GHz Core i7 Processor, ID iMac14,2
340回答 すべてを表示
Where did my desktop icons go when OS was upgraded
All my personal desktop icons disappeared when the OS upgraded. Can they be restored?
Don’t know what to tell you that would be helpful. I accepted an update to OS 10.13.1 and upon completion several hours later I no longer had any icons on my desktop that lowered there before; several of which were folders containing the text & WORD files I created over the last couple years. I CAN’T FIND THEM ANYWHERE. Very frustrating.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント:
What was your original OS and what are you running now? Also is your system a Fusion Drive config?
さんによる
コメントを追加
1 件の回答
you could check to see if there is folder called previous system or incompatible software. some times it is a hidden folder.
If there is a previous system folder then it is likely that you can recover then from there alternative if you have been using time machine you can find them there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Paul Hanz さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 66
