メインコンテンツにスキップ
モデル番号A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5もしくは 3.4 GHz Core i7 Processor, ID iMac12,2
708回答 すべてを表示
Click and then reboot
I received an iMac with the screen entirely taken off, I believe they tried to remove the hard drive before getting rid of it. In the process they damaged almost every connector from the LCD to the board, at least slightly. With great precision I think I salvaged the connections and the display seems to be working fine. So I put a new HDD in the machine, booted from USB to High Sierra, initiated the install from the first menu that lets you use Disk Utility, install, etc. with no problems. Then it kept randomly turning off and rebooting throughout the install (much more often than a normal install), I let it do its thing overnight to see if it would install. Came back this morning and the country chooser was up on the screen. I clicked United states, then next, and as soon as I hit the next button, the machine clicked, shut off and rebooted. It stays in a reboot loop for a while, and then gives me the country chooser again, and the same thing happens, click... reboot.
Any idea whats going on?
I don't think the semi damaged display cables would cause this to do this.
I reset the SMC, PRAM, Tried different power outlets and cables.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
At first I was thinking your power supply was going but the fact you can leave the system running and only during a set point in the installer it fails leads me to believe the issue is either a failing RAM module and/or your CPU is over heating going into thermal shutdown.
Fixing the RAM is the easiest to do. If your system is overheating then you'll need to start off by doing a full dust clean out (fans & logic board). I would also clean and re-paste both the CPU & GPU chip heat sinks and do a full inspection of the the heat sink heat pipes you might have a bad unit.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Taylor Struna さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 85
