Why won't windows install
It says windows installation cannot proceed
I will suggest you to check the BIOS settings provided below to see if you have similar settings. If not you may try these settings and then install the operating system.
Once the system restarts, Go to the ‘One Time Boot Menu’ by pressing F12 at the Dell logo 6-7 times.
Select the boot device under UEFI to boot.
In case you have other problems in installing Windows update, check out those methods.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 36
今までの合計 2,089
Is that all it says? no error code or anything? What type of installation media are you trying to use? disk? Flash Drive? Or OS reset?
Aiden さんによる 共有
