メインコンテンツにスキップ
The W123 chassis covers 240D's, 300D's, 300TD's, 280E's, and several other models of Mercedes coupes, sedans and wagons from model years 1977 to 1985.
116回答 すべてを表示
mercedes w123 rear right power window
Hi Guys
Regarding my w123 (250 engine):
1. My rear right power window goes up and down great from the switch next to the driver seat.
2. The window doesnt move from the switch that on the rear right window, thought its a switch problem i bought a new switch but it also doesnt work.
Any ideas how to solve the problem ?
thanks
A.Hershkovich
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
There are two items to check. First be sure the rear-window push-push safety switch is not activated. It is located in console next to driver's-side window switches. Purpose is to disable both rear door switches operation. If the safety switch is not depressed, inadvertent operation of the rear door windows (for instance, by children) is prevented (quoting the Owner's Manual). Both rear windows are affected when safety switch is enabled. Second, and typically affecting just one door, is broken wiring in the flexible conduit. The rubber tubing between jamb and door contains wires. Repeated flexing as door is opened and closed causes chafing and may lead to eventual failure. Carefully remove conduit at one end, then inspect wires for damage. Failure of the flexible conduit (cracking, tearing, punctures, etc.) accelerates wear of the wiring due to moisture intrusion and foreign matter accumulation (dust, grit, etc.). Repair wiring as required. Seal minor damage to flexible conduit with silicone sealer or equivalent. Significant damage to flexible conduit mandates replacement of the part.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
aviram herscovici さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 6
今までの合計 333
