メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
20回答 すべてを表示
Connected to wifi, but says "No internet connection"
As you can see from the title, I'm having trouble with an Iphone 6's WiFi connection. It detects all my networks but when I connect to it it says "no internet connection". I tried resetting the network settings, forgetting the network and even resetting my router. The networks wok with all of my other devices. I've also replaced the antennas inside the phone itself. I'm a tech at a repair shop and thankfully have a lot of parts laying around. Could it be a board issue or am I overlooking something?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 4
コメントを追加
4件の回答
What iOS version are you run on? Maybe try updating its software.
このアンサーは役に立ちましたか?
スコア 0
8 件のコメント:
it's on the most current update, 11.2.1
さんによる
Ok. I’m running iOS 11.2.5 beta on an iPhone SE. maybe try getting it checked at the Apple store.
さんによる
Have you tried connecting to a different WiFi network?
さんによる
I have not, there aren't any other networks near me.
さんによる
You can go to a cafe or library for free WiFi. I’m not sure where you are but if you can find any free WiFi or use your friends WiFi to check.
さんによる
3件以上のコメントを表示
コメントを追加
This could be the indicative of a failed board. Though replacing the board should be your last option, I believe it’s one of your only solutions. iPhone 6 の分解
Take note that the following link IS A TEARDOWN.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I don't believe this to be a hardware related issue. Its quite possible that that the device is blocked and stuck in that state with no clear method to unblock it. So I was able to fix this issue by doing two things. (reset network settings on mobile device and network settings on WiFi network).
1: Reset network settings on my iPhone Settings > General > Reset > Reset network settings
2: Reset my router/modem combination to factor settings and then reprogram/reconfigure to my old settings.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Thank you for your answer! I can reset my phone but the router isn't mine. Maybe just resetting my phone will fix the issue.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Brandon Desselle さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 3
今までの合計 18,939
