メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
このインスタントカメラは富士フイルム製で、前モデルと比べるとよりスリムに、より軽量なデザインです。Mini 8はフォトグラファーに適切な明るさの設定を自動で点灯して教えてくれます。またフラッシュ機能をハイキーモードに設定すればアーティスティックな美しいポートレート写真を撮影することができます。
My Instax Mini 9 film keeps coming out black.
I just got the camera and the first set of film came out black so I thought the film was ruined. I bought a new pack and put that in and it still comes out black. The flash goes off and I had it on the right settings.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 5
3 件のコメント:
I have the same issue. Has anyone figured this out!?
さんによる
My intax mini 9 pictures are dark at the top of the photos.
さんによる
My instax mini 9 pictures are dark around the edges but normal exactly where the flash was
さんによる
コメントを追加
4件の回答
I'm having the same issue and unfortunately I don't have an answer but I would contact customer support so you can replace either film or the camera if you are eligible for the warranty. Thats what I am currently doing and I wish you all the best!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I had this problem!! And I couldn’t find the solution online. It wasn’t the shutter in my case. There is a piece of black tape inside the camera, above the lens, blocking the exposure. Peel it off- problem solved for me. Hope it works for you too!
このアンサーは役に立ちましたか?
スコア 0
5 件のコメント:
was it a above the lens just below where the back of the camera opens? I have this same problem and there is a little piece of tape there but it seems like its supposed to be there
さんによる
Where exactly the tape is?
さんによる
Inside the camera, below the film.
さんによる
hmm mine looks like it should be stuck on as well. Did it look like that for you Molly?
さんによる
Wait where exactly is the tape? I saw a tiny black tape in the bottom of the film installing area in the back of the camera(it's stuck to the camera) I peeled it off but I don't know if that's the right one. >-<
Also, can anyone just send a photo of where the black tape is in their camera please? ._.
さんによる
コメントを追加
I have seen people who had this problem with the instax 8 say it was due to a black piece of tape above the lens that messes with the exposure so if you find something similar try removing that!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I was told it's problt cause of not enough lighting on the camera and make sure not to shake them
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Alyssa Cooney さん、ありがとうございました!
統計データ:
過去 24時間: 6
過去 7 日: 12
過去 30 日: 41
今までの合計 16,955
