メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
モデル番号A1707。 2017年6月に発売されたこのMacBook Proは、最大3.8 GHzのTurbo Boost搭載の最大2.8 GHzクアッドコアIntel Core i7プロセッサーまでのKaby Lakeプロセッサーを搭載しています。
What does the top case consist of?
Just curious as I've been heard because of issues with ports, the whole top case needs replacing.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
6件の回答
最も参考になった回答
Excuse me.
Do you know if the top case consists of the speakers? Apple will replace my top case and I wonder if the speakers are going to be replaced.
ps: MacBook Pro 15" Touch Bar 2017
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
If you are having the uppercase replaced as far as the extended warranty program for bad keyboard then yes the speakers, battery and trackpad are all replaced within a refurbished uppercase.
To be clear you are not getting a new part just refurbished one. They replace the keyboard and battery as well as test the rest of the part before reusing it.
さんによる
Thank you! Really appreciate it!
さんによる
コメントを追加
The case parts are made from aircraft grade aluminum.
Can you explain more fully what your issue is. How about posting some images so we can see the damage. The USB-C ports are mounted to the uppercase independently.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
Yes. The top case includes a new pair of speakers. I don’t know if this always happens, but my MBP 15” with TouchBar 2017 top case was recently replaced by a new one in a local Apple authorized service provider and it included: new battery, new keyboard, new speakers.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
did it include a new touchbar?
さんによる
@Arch Mauricio Bermudez - Yes, it is part of the uppercase assembly.
さんによる
コメントを追加
Ports are on the logic board, which is mounted in the top case.
Top case is mainly battery, keyboard and some other small components.
It should be under warranty if your model is this new
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Hi,
My MacBook is now under repair before the end of the 4 years period.
do they replace the top case with same butterfly keyboard or something different?
Thanks
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Very late but I'm wondering this as well. I've been told to replace the top case from Apple but my issue is crashing does that tally up?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@tr0llboy - That doesn’t make sense!
What is the crash reports telling you?
さんによる
コメントを追加
回答を追加する
John Hamp さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 16
過去 30 日: 55
今までの合計 48,950
