メインコンテンツにスキップ
2011年初期のモデル。モデル番号はA1278 / 2.3 GHz i5 or 2.7 GHz i7 プロセッサー。
782回答 すべてを表示
The LCD is "jumping" up and down + horizontal lines
The LCD on the MacBook Pro early 2011, 13" is "jumping" up and down and at certain display positions horizontal lines are running up and down the screen and the screen gets frozen.
And often it is only the half lower part of the LCD which is "jumping" up and down. The lines though are on the whole LCD.
At certain display positions it can work normally sometimes.
What can the problem be, can it be a display cable which is faulty? I don't think the actual LCD display is faulty since it works in certain positions.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
I would examine the LDVS cable as picture in step # 14 of this guide. Reseat it it and examine for any corrosion. MacBook Pro 13インチ Unibody Early 2011のディスプレイの交換
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Bad LVDS cable most likely. Could be the LCD or connector on the board but I would highly lean on a bad cable
このアンサーは役に立ちましたか?
スコア 2
1件のコメント:
I checked that cable on the motherboard side, all looks good and nothing happens when i move around the cable at that end.
But maybe the problem is at the LCD end of that cable?
Can i access that connector without removing the whole display unit from the rest of the computer? Can it be accessed by only removing the glass and then removing the screws for the LCD and then just move the LCD?
さんによる
コメントを追加
回答を追加する
Jon Smith さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 2
今までの合計 667
