Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
このアンサーは役に立ちましたか?
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
Yes I checked the door and it made contact but I was never able to get the camera working
過去 24時間: 0
過去 7 日: 1
過去 30 日: 7
今までの合計 815
