メインコンテンツにスキップ
The Canon PowerShot S90 is a high-end 10.0-megapixel compact digital camera originally announced in 2009.
6回答 すべてを表示
Full battery but won’t turn on
My s95 camera worked well last time I used it but now won’t turn on. I have already ordered a new battery and installed it but still no go. Is there an easy check I am missing?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
2 件のコメント
I’m having the same issue with my s95. Battery door compartment is all fine but still won’t turn on. Has anyone found a solution please help a girl out :(
さんによる
@christina73227 does your S95 give you any sign of life? Checked the battery, just to make sure?
さんによる
コメントを追加
1 件の回答
ベストアンサー
Ned Hascall start by checking the battery contacts as well as the battery door. If it does not make proper contact your camera will not get any power. Let us know what you get once you've replaced the battery.
このアンサーは役に立ちましたか?
スコア 1
3 件のコメント:
I am a having a similar issue and have replaced the batteries. Is their another step I can take?
さんによる
@Chris Cool Did you check the battery compartment door? If it does not make proper contact it will not work
さんによる
Yes I checked the door and it made contact but I was never able to get the camera working
さんによる
コメントを追加
回答を追加する
Ned Hascall さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 4
過去 30 日: 12
今までの合計 1,003
