battery flap broken can it be replaced
battery flap won't stay closed. can it be replaced
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi @brendadawsonitp ,
Here is a link to a video which shows how to replace the battery cover door on a Coolpix L22. I realize that this is not your model but it should be close enough to your model to be of some help.
Here is a link to the ifixit Nikon Coolpix L26 Camera Back Cover Replacement guide which should also be of some help in the repair.
Here a links to suppliers of the replacement part. It is not a recommendation to use them. It is shown to give you an idea of the cost of the part. There may be other suppliers online that suit you better. Just search for Coolpix L26 battery door cover part for results
https://www.aliexpress.com/item/original...
https://www.moderngeneral.top/nikon-cool...
Hopefully this is of some help
このアンサーは役に立ちましたか?
It looks to me like the material used in making the door is week and the spring pushing the batteries is way to strong. I've seen more of these cameras broke then I've seen working.
過去 24時間: 0
過去 7 日: 13
過去 30 日: 45
今までの合計 616
