How do I get it off of frp lock mode
Phone is on for lock mode and I can’t turn it off
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Turn on phone, go to settings, about phone, software info, tap on build number 7 times to enable developer options then enable OEM unlock under developer settings.
Or use the other method described here:
このアンサーは役に立ちましたか?
How the !&&* would this help if they can'r even turn the phone on??
How am I supposed to know that they have text at the top left of their screen with it being stuck on Samsung logo saying Custom Binary Blocked by FRP lock.
In any case reflash stock Samsung firmware that is the correct model and is at least the same or newer firmware will allow the phone to boot.
Most people will already know how to do this because they flashed stuff on their phone already to get at this stage.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 21
今までの合計 20,117
The phone will not even turn on ! It’s acts like it’s gonna start and then up in the top left corner of screen it say S
CUSTOM BINARY BLOCKED BY FAP LOCK ,and it’s in red .
And it just has black screen and symbols of the battery . I can’t figure it out , please help someone !
Simplysolo88 さんによる
Got the same problem plzzz help
mandisajoe さんによる
Buy an octoplus frp dongle from aliexpress and it will remove it
daniel さんによる
my phone is on a blue screen i dont know whats happening but it was starting to fry my charger pls help :(
Dominique Jackson さんによる
If you off devlper or oem unlock after fashing twrp you will get frp lock so reflash rom with odin
Amir Hussain さんによる
