Won’t charge battery
I have a two Boom speakers just the orginal Boom
I can plug the power adapter to charge and it will start charging but it will only charge for up to about a minute and then it will stop how can I fix this?
If your UE Boom speaker does not charge, see the UE Boom Won’t Charge or Loses Battery Quickly problem page for possible causes and solutions.
As in most cases, it could be a connection problem, here are some things you could do:
1) See if the charging port is not broken, if it is that may cause the speaker to not charge after X seconds/minutes
2) Have you tried using different cables/adapters? (For example 1A or 2A adapter or a different Micro USB cable)
3) In rare cases the speaker will "block" incoming electricity to prevent it from further charging, I've seen this with other devices before and you'll just have to be patient and try using it and replugging it every now and then over a short period of time.
4) And of course, if you can, try to exchange this one for a new, working speaker
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 3
過去 30 日: 12
今までの合計 7,971
