メインコンテンツにスキップ
モデル番号A1419 / EMC 3070 / Mid 2017 / 3.4, 3.5もしくは3.8 GHz Core i5もしくは4.2 GHz Core i7 Kaby Lakeプロセッサ (ID iMac18,3) / Retina 5Kディスプレイ。システムは類似しているため、修理ガイドについては旧モデルのiMac Intel 27インチ Retina 5Kディスプレイ (Late 2014 & 2015) を参照してください。
293回答 すべてを表示
Can I upgrade the HDD portion of the fusion drive setup on my iMac
I’m not looking to touch the PCIe SSD my system has. I want to know if I can just upgrade the HDD portion to an SSD instead of using the slower 7200 rpm HDD.
If so, will it be possible to “fuse” the stock PCIe SSD and new SSD or will there basically be just two SSD's seen in the OS?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
3 件のコメント
Actually I was able to successfully swap the 2TB HDD for a 2TB SSD from OWC. I then proceeded to install the OS using an Internet Recovery. Formatted the stock Apple 128gb SSD as a separate drive. Then rebooted into recovery using COMMAND R. Used Terminal to construct my own Fusion Drive using the SSD and Stock Apple SSD and then was able to reinstall the OS once more on a newly constructed Fusion Drive made up of two SSD’s. Badaboom! It can be done! Thanks anyway though.
さんによる
The OS used was Sierra.
さんによる
I wouldn't trust it Apple never intended a dual SSD setup with Fusion Drive.
さんによる
コメントを追加
2件の回答
ベストアンサー
In the past the answer would be no as Sierra and older OS's leveraged the device type to set the way Apples 'Fusion Drive' worked. With it you needed one SSD and one HDD.
Right now we just don't know what Apple is doing as High Sierra redid the lower level structure from GUID/MacOS Extended (Journaled) to GUID/APFS. This may still be the way you'll need to go.
At this time High Sierra APFS Fusion Drives are not supported and RAID drives are also not working either. So we'll need to wait to see what happens. Will Apple fix APFS and when?
So what can I do now?? You'll need to leave the drives independent and just make sure you set the PCIe SSD as your boot drive.
Now the tricky part! The SSD Apple was using in a Fusion Drive is quite small FYI: Gizmodo - Apple Quietly Made the Fusion Drive Much Smaller So you may find it's not able to support your OS and Apps as well as have any spare space for virtual RAM (paging in Windows). You may want to add more RAM if you only have 8 GB to off set the smaller SSD's size.
You might want to forgo setting it as the boot drive as what you are using the system may be too much for the small drive.
As you where very clear you didn't want to alter the PCIe drive you might want to look at that again or look at getting an external RAID'ed Thunderbolt SSD drive.
Frankly, I would leave the system alone and go with the faster external RAID'ed SSD setup and make that my boot drive (Sierra only)
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
If you haven't bought your system or can return it I would do that and get as big a PCIe SSD drive only system as you can afford (1 or 2 TB SSD). Then later you can upgrade it with a HDD.
さんによる
コメントを追加
While a fusion drive using two SSD’s may have been possible with High Sierra, it is not possible with Mojave.
The “coreStorage create” command only allows one HHD and one SSD to be fused.
Also Mojave will not allow you to format the Logicboard SSD as anything other than APFS.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
David さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 1,150
