メインコンテンツにスキップ
2014年9月19日に発売されたiPhone 6の修理情報とガイドです。モデル番号 A1549、A1586、A1589。
4994回答 すべてを表示
Why is my lock button not working anymore?
Hi there,
I decided to renew the hardware of my iPhone 6 in order to extend its life and bought a new battery, lighting and jack connector, earpiece and loudspeaker from ifixit Europe.
Replacing components was pretty easy thank to the guides I found on the website and I did it all in one go.
The only exception was the removal of the old battery. I tried taking away the glue stripes as shown in the guide, but they broke and went under the battery, so I had to lever it out with some of the tools. I am afraid I may have damaged something because when I reassembled everything, the lock button didn't work anymore.
Now it may not depend on the way I removed the battery, maybe I just moved something without noticing(?).
Does anyone know what I can do to check what happened?
Any help is much appreciated.
Thanks
St3fan0
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
You may follow this step:
Power off
Remove the front screen assembly
Remove the battery
Unplug the dock connector assembly
Remove the logic board
Fix the stuck power button
Replace the logic board
Replace the battery
Reconnect the display assembly
est your newly fixed iPhone 5 power button
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
st3fan0 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 4
過去 30 日: 5
今までの合計 3,204
