No Wifi in network
There is no wifi in the network system preferences.
Under system report it shows no Wifi.
Installed completely new OSX High Sierra.
Purchased new Blue Tooth Wifi card from iFix it.
All to no avail.
Blue Tooth works fine.
Since the Bluetooth and AirPort Card are one unit, I would try reseating the cable and card, see if that works. It is possible, while unlikely that you got a bad part from iFixit. If reseating and reconnecting of the cable and and card don't work, I would try getting iFixit to send you a replacement. It is also possble that the cable is messed up, a new one can be purchased here and a guide is here.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 4
今までの合計 75
I have that issue too. I asked before and haven't gotten an answer so good luck!
Aiden さんによる
