Can you replace my OS framework or replace motherboard?
Samsung update has corrupted my android OS and I need it fixed or motherboard replaced
この質問は役に立ちましたか?
この質問は役に立ちましたか?
You will need to reflash Samsung official firmware on the phone. Since the phone is in bricked state you will not be able to backup the phone.
http://updato.com/how-to/how-to-install-...
Follow this guide and make sure you try flashing home_csc first instead of CSC to avoid factory reset unless it's needed.
You will need to hold volume down + power + home until you get the download mode prompt screen
Same keys, volume up if you want to boot recovery.
Same keys volume down if you want to force shut off phone when holding it for longer.
このアンサーは役に立ちましたか?
Hey man, if your OS has gotten corrupted I would consider a factory reset through recovery mode.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 183
2 件のコメント
@noronicscodez how did the update corrupt your OS?
oldturkey03 さんによる
have you tried a factory reset ?
Jimfixer さんによる
