メインコンテンツにスキップ
2016年9月16日に発売。モデル番号は1660, 1778で GSM かCDMA があり。/ 32、128、 256 GB / 色はローズゴールド、ゴールド、シルバー、ブラック、ジェットブラック
2264回答 すべてを表示
Why is my iPhone 7 boot looping after a screen replacement?
So a few days ago i bought a used iphone online. It had a cracked screen but worked just fine. I ordered a new screen and replaced it. After replacing it the problems started to happen. It would continuously boot loop.
I've tried to restore it using itunes several times. Sometimes it worked, but i couldn't get past the "hello" screen as the home button doesn't work anymore... I had to turn it back off in hopes it would start at language selection screen. Unfortunately, almost every time it shuts off it would go back into a boot loop. I've tried reconnecting the old screen too, but it's still boot looping.
I'm wondering if this is a software issue or if it's a hardware issue. If it is a hardware issue, is it the screen that sends it into a boot loop or can it be due to something else?
Any help would be much appreciated!
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
3件の回答
ベストアンサー
A lot of things can cause boot-looping. However a clue in your comments is that when everything did work fine (sort of) that the Home Button didn't work. You may have slightly damaged the Home Button when you replaced the screen and migrated the Home Button over.
I would open up the phone and closely inspect with magnification the Home Button, especially the flex cable for any damage or tears. Follow this guide. I would also closely inspect the connectors for the screen assembly.
このアンサーは役に立ちましたか?
スコア 4
コメントを追加
Did you try updating your software? iOS 11 has had issues with replacement screens. The newer ios’s Is supposed to fix those issues. Put it in safe mode and update.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Same issue here. Everything works fine but i can’t make a call or it goes into boot loop. I think its an apple scam to get me to buy a new phone
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
JAB さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 7
過去 30 日: 7
今までの合計 7,568
